I need to build special equipment for a microwave oven ( 2.45 (GHz)). But even glass and plastics do heat up in microwave ovens. Where can I find a list of the materials that are the most transparent to this frequency ?
Thanks
Sign up to join this communityI need to build special equipment for a microwave oven ( 2.45 (GHz)). But even glass and plastics do heat up in microwave ovens. Where can I find a list of the materials that are the most transparent to this frequency ?
Thanks
Selecting a material with a low dielectric constant (Relative permittivity) will be the most transparent. Specifically, you need to select one that is low for the use temperature and for the use frequency of 2.5GHz. This level of information is not easy to come by, but there are some online tables that will give ballpark dielectric constants. Looks like polypropylene is a common consumer material for use in microwave ovens.
