-1
Currently I am doing a project on heat transfer .I have considered a system in which , there is a chamber with desired volume (1 m3 ).Air is filled inside the chamber at 5 bar and 35 degree Celsius .There will be a tubular heat transfer unit inside the chamber. Water is flowing through the tube at a particular flow rate . Inlet temperature of water is 90 degree Celsius. I need to raise the air temperature to 80 degree Celsius. As of my initial impression there will be a forced convection from flowing water to the tube body , natural convection from tube body to air in contact with tube surface and radiation heat transfer with in the chamber volume . I would like to know how do I find the heat transfer rate from water to air , final temperature of water after particular time and length of tube.
  • $\begingroup$ This is a good reference to start : link.springer.com/book/10.1007/978-1-349-15605-4 $\endgroup$ – Solar Mike Jun 21 at 5:53
  • $\begingroup$ Do you think the water to pipe heat transfer will be conduction? $\endgroup$ – Solar Mike Jun 21 at 7:07
  • $\begingroup$ no. water to pipe will be forced convection. from inner surface to outer surface of tube there will be conduction. But i think it can be neglected . $\endgroup$ – BINSON VARGHESE JOSEPH Jun 21 at 7:41
