my team is working on a project where fluid (mostly water) need to be pushed through small channels (like small pipes) in order to reach larger reservoir. We were considering using air to push the water but we fear that the water will simply bubble through the water. Does anyone have any advice on how to work around this to move the water through the channels?
$\begingroup$ A diagram may help with dimensions... $\endgroup$– Solar MikeJun 15, 2019 at 20:27
$\begingroup$ @SolarMike done, let me know if you need any other information. Mostly looking for a direction to look toward. $\endgroup$– Peter ConnorsJun 15, 2019 at 20:36
yes. knowing the surface tension of the fluid and its contact angle with the channel walls, you can select a channel width that does not support two-phase flow, where bubbles and fluid can pass by one another and get mixed up in the channel.
For example, the tube diameter on a turkey baster's tip is made small enough so that air cannot flow up in the tube while juice flows down, which would cause the baster to spill out its contents.
The tradeoff between the effects of capillarity and inertial or gravitational effects is what sets the break point between the baster holding its contents and spilling them. The nondimensional similitude parameter that establishes this is called either the Froude number or the Weber number, I cannot remember which.
A cheap way to realize low pressure differences (and a method that is nearly unbeatable for smoothness) is gravity. Fill everything with liquid, run input and outlet tubes to two beakers/buckets/etc, with the one on the input side be higher than the output. Approximately 1 mbar per centimeter height difference for water at room temp.
