-2
The work done by a turbocharger increases the inlet charge without much of a burden to the exhaust flow. This increases the amount of air (and fuel) that flows into the engine. How does this affect work done for a given amount of fuel consumed?
  • 3
    $\begingroup$ Possible duplicate of Does the turbo-compressor increase the efficiency of car engine? $\endgroup$
    Jun 9 '19 at 23:43
  • $\begingroup$ Before asking my question, I had read the referenced post, and hesitated to do so for that reason. However, after reading it and previously many related discussions on other sites, I felt that the question should be asked and categorized differently, which would yield more data. $\endgroup$ Jun 11 '19 at 6:43
  • $\begingroup$ Any thermodynamics textbook will show how this is calculated... I still use Rogers & Mayhew... $\endgroup$
    Jun 11 '19 at 6:45
It's complicated and depends on application and demands such as emissions restrictions and required throttle response, but generally, figure on about a 2 percentile improvement with a turbo. An example would be going from 34% to 36% thermal efficiency by adding a turbo.
You can see this for yourself if you look at the BSFC fuel maps of a family of engines that include turbo and normally aspirated versions.
Yes, turbocharging improves both the volumetric and thermal efficiency.
But as most drivers tend to use the power that does not always translate to an improved fuel consumption.
