enter image description here The speed of the induction motor is starting from around synchronous speed. The speed should start from zero. What is the reason behind that?
    $\begingroup$ Without seeing the code, it's impossible to answer your question. $\endgroup$ – Sam Farjamirad Jun 1 at 11:33
    $\begingroup$ Do you set the initial speed of motor to 0? $\endgroup$ – StainlessSteelRat Jun 3 at 17:08
