I am looking for a away I can convert the horizontal rotation into vertical, typically we use bevel gear for such thing. But I am using a SG90 servo motor for which I am struggling to get the correct gears to achieve my requirement.
I am not sure is there is any other way I can do this using the SG90 servo motor. I am looking for something which I can 3D print if nothing is readily available.
  • $\begingroup$ a flexible cable as used for drills... $\endgroup$
    May 16, 2019 at 10:21
  • $\begingroup$ Do you any image or youtube video to show how it works? $\endgroup$
    – uday8486
    May 16, 2019 at 11:34
  • $\begingroup$ Do a google search - Bowden cable may be a good start... $\endgroup$
    May 16, 2019 at 11:51
  • $\begingroup$ Link to a data sheet. I suspect that you mean the Tower Pro SG90 RC servo (which is not a "servo motor", regardless of what people may call it) -- but no one can be sure. $\endgroup$
    – TimWescott
    May 16, 2019 at 16:33
  • $\begingroup$ Why can't you mount the servo on it's side? Do you need both vertical and horizontal motion? $\endgroup$
    – TimWescott
    May 16, 2019 at 16:34
