I have a motor with a 4mm shaft. I've purchased a propeller that's designed to fit a 1/2 inch shaft. How can I securely couple the two?
    $\begingroup$ Have you asked yourself if attaching something designed for a 1/2 inch shaft with all the weight and strength requirements that implies is a sensible thing to attach to a motor with a 4mm shaft, with all the (lack of) strength which that implies? $\endgroup$
    – TimWescott
    Commented May 9, 2019 at 16:13
3 Answers 3
If the motor speed matches the speed range needed for the prop, then make an adapter with relevant locking screws or equivalent, balanced as necessary.
something like :
Source https://shaft-collars-couplings.staffordmfg.com/viewitems/shaft-adapter-couplings/shaft-adapter-couplings---step-up-type-with-keyway
  • $\begingroup$ Can you be a little more specific? I'm kind of a neophyte here. $\endgroup$ Commented May 9, 2019 at 12:12
  • $\begingroup$ @Megalonychidae see update $\endgroup$
    Commented May 9, 2019 at 12:24
  • $\begingroup$ Perfect! Thank you very, very much. $\endgroup$ Commented May 9, 2019 at 18:06
Following on from Solar Mike's answer, I'm not sure you'll be able to find something off-the-shelf with the diameters you have (mix of imperial and metric units), so you may need to get something custom made instead. I have sketched the following (not knowing what shaft lengths you had, I made a few assumptions - adjust to suit your needs):
The outer diameter is 1/2 inch, while the ID is 4mm. I have toleranced it as H7 hole so that it's a snug fit on the 4mm shaft. The adapter is secured onto the 4mm shaft with 2 M3 grub screws at 90 degrees, you can also use Loctite 638 if you want to be sure. I have added a 1mm chamfer on the end of the shaft adapter.
  • $\begingroup$ Good job, plus 1. $\endgroup$
    Commented May 9, 2019 at 18:07
  • $\begingroup$ Beautiful sketches, do you mind if I ask what software you used? $\endgroup$ Commented May 9, 2019 at 18:08
  • $\begingroup$ Thanks. I used Autodesk Inventor. $\endgroup$
    – am304
    Commented May 9, 2019 at 18:28
Use gears, mechanical losses will only be 1 % and that's negligible.
