This is a continuation of me trying to understand torque and stepper motors in my other question. I'm trying to understand the torque a motor would be required to generate to lift a small weight, and the formulas involved.
The first part of my question is to verify if I am calculating this correctly:
Let's say I have a 450 g mass (roughly one pound) then the force of gravity pulling it down is:
$\begin{align} F &= ma \\ &= 0.450 \:\mathrm{kg} * 9.8 \:\mathrm{m}/\mathrm{s}^2 \\ &= 4.41 \:\mathrm{N} \\ \end{align}$
If I have a stepper motor with a spindle for my string that pulls up my motor with a radius of 5 cm. I think my torque needed would be:
$\begin{align} T &= Fr \\ &= F * 0.05 \\ &= 0.22 \:\mathrm{Nm} \\ \end{align}$
So now if I want to move that mass I need to find a stepper motor that can output more than 0.22 Nm of torque, right?
The follow-on to my question is that if I want to see how fast I can move it then I need to look at a Torque speed curve, right?
My confusion is this: do I have to ensure that I'm moving slow enough to get the torque I need, or does that curve say if you need this torque you won't be able to go above this speed because the motor won't let you?
