What is the principle of a fogging machine ? on what process a fogging machine depends ? distillation or vapourization ? what is the harmful effect of fogging machine ?
$\begingroup$ Have you done any research? a google search should give you the answers. $\endgroup$ – Solar Mike Apr 29 '19 at 19:55
$\begingroup$ First result for "fog machine liquid ingredients" looksolutionsusa.com/are-fog-machines-safe $\endgroup$ – Jonathan R Swift Apr 29 '19 at 19:56
$\begingroup$ Normally you would prefer to use a hazor instead of a fog machine if you can. $\endgroup$ – joojaa Apr 29 '19 at 20:44
