I'm searching for a mathematical approach to well describe the creep (or stress relaxation)of helical-coil compression spring.I've got the spring parts and can Experiment with these parts .I need extra theoretical analysis which my experiment is trying to support.
$\begingroup$ Related: engineering.stackexchange.com/q/2242/33 $\endgroup$ – hazzey♦ Apr 26 '19 at 15:01
$\begingroup$ You need to understand Young's Modulus for the metal and determine the minimum load before creep occurs and the relation between it and fourth dimension leading (time) $\endgroup$ – Rhodie Jun 8 '19 at 14:58
Add a comment
