12
I am wondering if there is a spring strong enough and light enough to inflate an airtight membrane so that it floats at Standard Temp & Pressure.
As an example, a 10cm cylinder would displace just under 1 gram of air, but a cylindrical spring would have to oppose 162kg of atmospheric force in that configuration. Is there such a thing as a 162kg 10cm cylindric spring that weighs less than 1 gram?
But that's just one spring design. More generally, what spring designs provide the highest rate/weight ratio? What are the current practical limits on spring rate vs spring mass, and using what materials?
13
  • $\begingroup$ I'm not sure I fully understand your question. You speak of a "10cm cilinder" and how much (volume) air it displaces, but not all dimensions are given. And where does that 162kg come from? If you can add a drawing it should help a lot. $\endgroup$ Jan 21, 2015 at 9:41
  • $\begingroup$ I think OP might be talking about the spring (which is in a vacuum) exerting force on a membrane, which therefore increases the volume of the spring-membrane system, rendering the entire system buoyant enough to float in the air. $\endgroup$
    – March Ho
    Jan 21, 2015 at 13:42
  • $\begingroup$ @VladimirCravero: 10cm cylinder is 10cm diameter and 10cm high. 162kg comes from standard barometric pressure ~1.033 kg/cm2 bearing on the top and bottom surfaces of the cylinder, which are on the only compressible dimension in the described system. MarchHo: exactly right! $\endgroup$
    – feetwet
    Jan 21, 2015 at 14:09
    $\begingroup$ Isn't it fairly obvious that helium gas is rather effective at this? Other than that, I don't understand the question. What rigid, yet weightless material is your "cylinder" made of? $\endgroup$
    – Dave Tweed
    Jan 21, 2015 at 17:55
    $\begingroup$ Well, there is an answer to this question, at least from today engineering standpoint: No. - But a detailed one has to explain why. The subquestion, which is the lightest spring with the highest k is okay. $\endgroup$
    – JHK
    Jan 21, 2015 at 20:01
I know your question is about springs, but I don't think that springs are the answer to your desired application.
As you mentioned, the inward force from air pressure is very large so not only do you need a strong spring, but you also need a material for the paneling which is light and can take those kind of forces. Additionally, you would need to evacuate the air that seeps in through the material at a molecular level. There are good reasons lighter-than-air aircraft use a low-density gas inside the balloon:
  1. There is no requirement for exceptionally strong and light materials.
  2. There is no (or very low) pressure differential between the inside and outside, and therefore no tendency for the gas to escape or the atmosphere to seep in.
You may be interested to read the Wikipedia article on vacuum airships, in particular the section on material constraints. This shows the proof that even using a strong shape (hollow sphere) made of diamond, the pressures are too great for the structure to withstand once you thin it down to be light enough to become buoyant.
Flying Boat
Given that in these ideal conditions it is not possible, it seems unlikely that a spring in a balloon would be possible. However, the Wikipedia article does leave open the possibility that if the wall of the sphere was not solid, for example if it was made of a honeycomb structure, then it may still be possible.
Update: Apparently the maths has been done to show this is possible in theory, but it's not clear if it has been successfully implemented.
  • $\begingroup$ Together with my coauthor, I did the math (finite element analysis) for a sandwich sphere with honeycombs. It is possible to make a vacuum balloon with currently available materials. Please see the reference to our patent application in the Wikipedia article. $\endgroup$
    – akhmeteli
    Apr 30, 2015 at 1:08
  • $\begingroup$ @akhmeteli oh wow, that's very cool! Could you please edit the question where I said "I have no idea if anyone's done the math" to cite yourself as having done the math and what your conclusions were. As far as I can tell the comment in the article still stands... it may be possible but hasn't been done yet? Your edit will have to be approved, and you'll get some rep for it. Oh, and welcome to Engineering.SE :) $\endgroup$
    – jhabbott
    Apr 30, 2015 at 1:43
  • $\begingroup$ Thank you for the kind words. I am not a big fan of editing anything though, but if you have questions, I will try to answer. $\endgroup$
    – akhmeteli
    Apr 30, 2015 at 1:55
