I am working with a very simple 3-DOF damped LTI spring-mass system. As an exercise I am altering two parameters simultaneously (stiffness and damping coefficients connecting mass 1 to mass 2) to see which combination minimizes:
  • Settling time
  • Overshoot
The objective is to determine which parameter has the greater effect on the performance, either the stiffness or the damping.
My question is: How can I determine if changing stiffness or damping is having more of an effect on the aforementioned criteria ? Is there a way to quantify how they contribute to the performance ?
9
    $\begingroup$ What do you mean by performance ? Is there some quantity you are trying to minimize ? $\endgroup$ – Nicolas May 13 '15 at 14:53
    $\begingroup$ @Nicolas I am looking at settling time and overshoot as parameters of performance. But mostly what I am interested in is figuring out whether stiffness or damping has a greater effect on these parameters. $\endgroup$ – willpower2727 May 14 '15 at 11:59
    $\begingroup$ So you basically have some forcing terms (like an impact) and let the system damp out the response ? $\endgroup$ – Nicolas May 14 '15 at 14:24
    $\begingroup$ @Nicolas I'm testing step input. Yes I let the system reach steady state $\endgroup$ – willpower2727 May 14 '15 at 15:36
    $\begingroup$ Maybe you could edit your question and add those details. In this way you would get a far more precise answer $\endgroup$ – Nicolas May 14 '15 at 16:28
Equations of Motion
From what I understand from the question and your comments, you can write the equations of motion of the 3-dof oscillator in the form:
$$M \frac{d^{2}x}{dt^{2}} + C \frac{dx}{dt} + K x = f$$
where the vector $x$ represents the displacements, $M$, $C$ and $K$ are the mass, damping and stiffness matrix respectively, and $f$ is some forcing vector (e.g. impact, step function, etc.). Therefore, this type of equation may be classified as a Linear Time-Invariant (LTI) system.
Damping models
There are several ways to solve this type of LTI systems, for instance numerical time integration, and as mentioned in the response by @am304, different models to represent the damping matrix $C$.
Rayleigh damping is indeed one form:
$$C = aM + bK$$
where parameters $a$ and $b$ are chosen arbitrarily. You could also use modal damping, which is similar and may be written in the form:
$$V' C V= 2 x_iW$$
where $W$ is a diagonal matrix containing the linear eigenvalues of your system, $V$ the associated eigenvectors and $x_i$ is the damping coefficient (which may vary from mode to mode but can be considered as a single constant as a first approximation). The main advantage of this method is that the damping carries with it the inherent dynamics of your linear system and is diagonal in the modal domain.
Performance
In terms of performance, with respect to the overshoot and the settling time, they will be both dependent on the damping term as well as the stiffness, since the two quantities are related in the two modeling strategies here proposed. However, for a given stiffness matrix, the solution will reach a steady-state with a specific amplitude, and the overshoot and settling time will solely depend on $x_i$ as shown in the picture below (Last mass displacements for: $x_i=0.2$ (blue), $x_i=0.5$ (red) and $x_i=0.8$ (black)).
Last mass displacements for: xi=0.2 (blue), xi=0.5 (red) and xi=0.8 (black)
The main effect of changing the stiffness will be on the natural frequencies of the system, the effect on the damping will be secondary in my opinion. There are plenty of damping models available out there (e.g. hysteretic damping), and modelling damping is more of an art than a science, but the most basic damping model is viscous damping, where the damping coefficient is proportional to the relative velocity of the masses.
For an in-depth study of damping models see Damping Models for Structural Vibration.
