In modeling a wing with the finite element method, I am asked to consider an engine (approximated as a lumped force and moment) and it's mass, inertia, prestress and gravity contributions.
So the engine contribution (in terms of mass and inertia) to the Virtual Work is:
$$\delta \mathcal{W}_{engine} = - \delta s^{T} M \ddot{s} - \delta \theta^{T} J \ddot{\theta}$$
where $s$ is the displacement of the engine.
How should I add the prestress and the pendulum-like contribution?
  • $\begingroup$ That would depend on your model. Does your model has rotational degrees of freedom? $\endgroup$
    – nicoguaro
    Jun 13, 2019 at 15:06
  • $\begingroup$ yes, the wind can rotate and bend. $\endgroup$ Jun 14, 2019 at 16:57
  • $\begingroup$ Not the whole thing. Each single node of your model. $\endgroup$
    – nicoguaro
    Jun 14, 2019 at 17:01
