I am trying to design a gear that has a 1:2 speed ratio (input:output). This design is very limited in space and for simplicity and space savings requires the input and output shafts to be coaxial.
This leads me to think of using a planetary gearset, but in order to achieve a 1:2 gear ratio, we must use a fixed planet carrier gear, which reverses the direction of the output, which is not desired. Using a fixed ring or sun is not possible when targeting a 1:2 ratio because the ring and sun would have to be the same size. Am I missing something, or is there no simple way to make a 1:2 gear ratio with coaxial shafts, or do I require a reverse gear attached to the output of a planetary gear with fixed planet carrier?
