I have following example (the question is at the bottom):
The load distribution $q$ is constant. I add condition of zero bend in center of the beam, $w_B = 0$, and the assumption $F_{RA} = F_{RC}$. So I have:
$$F_{RA} + F_{RB} + F_{RC} = q\cdot 2 L$$ $$F_{RB} = 2 q L-2 F_{RA}$$
Divide beam to two sections (from left)
I. $x_1\in\{ 0;L\}$
$$M(x_1) = F_{RA} \cdot x_1 - q \frac{x_1^2}{2}$$ $$\frac{\partial M(x_1)}{\partial F_{RB}}=0$$
II. $x_2 \in\{0;L\}$
$$M(x_2) = F_{RA} (L + x_2) + F_{RB}\cdot x_2 - q \frac{(L + x_2)^2}{2}$$ $$\frac{\partial M(x_2)}{\partial F_{RB}}=x_2$$
Use condition $w_B = 0$ $$w_b = 0 = \frac{1}{E\cdot I_z} \left ( \int_0^L M(x1) \cdot \frac{\partial M(x_1)}{\partial F_{RB}} dx_1 + \int_0^L M(x2) \cdot \frac{\partial M(x_2)}{\partial F_{RB}} dx_2 \right )$$
$$0 = \int_0^L M(x2) \cdot \frac{\partial M(x_2)}{\partial F_{RB}} dx_2 = \\ \int_0^L \left ( F_{RA} (l + x_2) + F_{RB}\cdot x_2 - q \frac{(l + x_2)^2}{2} \right ) \cdot x_2 dx_2 $$
Substitute for $F_{RB}$
$$\int_0^L \left ( F_{RA} (l + x_2) + (2 q L-2 F_{RA})\cdot x_2 - q \frac{(l + x_2)^2}{2} \right ) \cdot x_2 dx_2 $$
Solve for $F_{RA}$
$$F_{RA} = \frac{1}{4} q l$$
It's this result correct? It seems suspicious to me. I supposed $F_{RB}\geq F_{RA}.$
    $\begingroup$ AISC Steel Construction Manual Tables 3-22c and 3-23 (14th Edition) are extremely useful for gut-checks of this type. slideshow available here $\endgroup$ – CableStay Aug 19 '15 at 21:18
This problem can be simplified by observing the symmetry. This allows us to solve only one side, considering it as a beam of span $L$ which is fixed and pinned:
Now, reactions are really just concentrated loads, so lets replace that pinned support with a concentrated vertical load $P$. To obtain $P$, we first take a look at how the beam deforms without the pinned support (i.e. just the cantilever). A simple cantilever has a total vertical displacement at the end equal to $d_q = \dfrac{q\cdot L^4}{8EI}$. Now, I lied. A reaction isn't just a concentrated load. It's also knowledge of the true displacement. We know that the end of the cantilever actually has a displacement equal to 0. Therefore, the concentrated load $P$ has to create a displacement that cancels out the value we calculated above. Now, a cantilever with a concentrated load at its extremity has a vertical displacement equal to $d_P = \dfrac{P\cdot L^3}{3EI}$.
Now, to cancel out, we need $d_q = d_P$. Therefore, we have
$\dfrac{q\cdot L^4}{8EI} = \dfrac{P\cdot L^3}{3EI} \therefore P = \dfrac{3qL}{8}$
So $F_{RA} = F_{RC} =\dfrac{3qL}{8}$ and $F_{RB} = 2\cdot\dfrac{5qL}{8}$ (it's times two, once for each side of the real beam).
It anyone's interested, the figures were created with Ftool, a free 2D analysis tool.
I can see the partial derivative, $\frac{\partial M(x_1)}{\partial F_{RB}}=0$ on your X1 section is actually not correct, it should be " = x".
An easy hand calculating method of these simple problems is using moment distribution method. Using symmetry we start from left hand span and assume fix ends initially then release them.
RA = RB ql/2 and MA = MB = ql^2/12.
now we release the joint A half of the moment is carried to joint be so now the MB = ql^2/12 + ql^/24 = 3ql^2/24 = ql^2/8.
Now we calculate final RA after moment distribution: RA = ql/2 - ql/8 = 3ql/8.
We set the RC = 3ql/8 too by symmetry. Now RB = 2ql - 6ql/8 = 10ql/8. 10/8 ql = 5/4 ql.
