I am rebuilding a mini soil compactor roller.
I replaced the old 8 hp Kubota diesel engine unit with a new Dongfeng unit. I want to weld the coupling shaft, which is built from 2" pipe with rubber damper at one end, to the hydraulic motor.
How can I ensure the shaft is balanced after we weld it to the flywheel? We would like to do this cheaply if possible.
