It's a known fact that you cannot place a curtain near a radiator because it will trap hot air behind the curtain and also block cold air from going through the radiator from bellow.
But obviously there must be a minimum distance you can place a curtain that goes from ceiling to floor in front of the radiator that would allow it to do its normal work. What is this distance in centimeters(hopefully) ?
As you can see the air can go up and to the room from the sides
I placed the curtains 10 cm in front of the radiator so that it doens't stop airflow, I hope this is good enough
