Checking with elastic capacity or plastic capacity depends on the limit state you are designing in:
- For design check in the Serviceability Limit State (SLS) you are interested in small deflections. So you use the elastic resistance of the section.
- For design check in the Ultimate Limit State (ULS) you are interested in the final resistance capacity of the section well beyond the small deflections. So you use the plastic capacity of the section.
Assuming that you are designing the end-plate in the ULS (which is the most common scenario) reading the Eurocode carefully gives the answer; In clause §5.5.2 (1) it says "The role of cross section classification is to identify the extent to which the resistance and rotation capacity of cross sections is limited by its local buckling resistance."
Assuming that the end-plate is perpendicularly connected to the member, the plate resists bending about its weak cross-sectional axis. Meaning that the bending in the lateral direction is resisted by the strong cross-sectional axis. So you shouldn't be worried about structural instability in bending (i.e. Lateral Torsional Buckling) of your plate cross-section. So your plate cross-section will behave similar to a Class-1 or Class-2 section; meaning that it will plastify and form yield lines between the supports (bolts or welds) and the member. Then this topic gets deeper into membrane behavior of the plate etc.
Now you can decide whether you need to use the elastic or the plastic capacity.
