I am trying to figure out how to calculate either the distance or angle of 2 Idler Gears in a Timing Gear Configuration like so:
I have been able to eyeball things, so they are approximate. I would like to come up with an equation to get an exact number for either dimension A or B. I came up with an angle for A of approx 44.7 deg where all the teeth mesh.
UPDATE:
I was able to use CAD to figure out how this needs to be done. Now I just need to figure out how to calculate all of this:
Basically what I ended up doing is all the angles are multiples of the tooth angle for each gear. Next I took a line at the tangent points of each gear perpendicular to a connecting line between each angle. See the blue lines in the above picture.
In this problem the tooth angle can not be used to calculate the spacing directly because of the gear mesh as seen on the bottom of the 22 tooth gear as seen in the top picture. The meshing actually takes place off of the tooth angle.
Just to clarify I am using 64 pitch gears, the diametrical pitch is calculated using standard gear equation:
Dp = N/P
Where:
N = Number of teeth
P = Pitch
