10
If a permanent room or platform is suspended from a larger structure (say, on a cable that is attached to a hook on a track in a ceiling) and designed to be in constant but not necessarily repetitive motion, does the load that the room/platform places on the larger structure count as a dead load or a live load?
On the one hand, it is permanent and won't ever be removed (like a dead load,) but on the other hand, it moves (like a live load.) I'm not talking about the loads that would be incurred by its motion, only by its weight.
  • $\begingroup$ Your title makes no sense. $\endgroup$ Apr 28, 2015 at 12:57
  • $\begingroup$ Not necessarily. It's just a new (or unused, to my knowledge - probably not new) idea, and it's dubiously practical. $\endgroup$
    – Matt
    Apr 28, 2015 at 15:23
  • $\begingroup$ The idea isn't that strange, lots of buildings have portions that move and this very question has to be addressed. $\endgroup$
    – Ethan48
    Apr 29, 2015 at 4:17
    $\begingroup$ The most obvious example is a crane on a gantry. Lots of the crane gubbins move around, sometimes with payload on and sometimes not. So although the payload is clearly live load, this question addresses whether the moving crane gubbins are dead or live. $\endgroup$
    – AndyT
    Apr 30, 2015 at 12:08
    $\begingroup$ This might fall under the term "quasi-permanent" in Eurocode. If I find some time to do some more research into it, I'll develop that into a full answer. $\endgroup$
    – AndyT
    Apr 30, 2015 at 12:16
3 Answers 3
9
What is the difference between a Live or Dead Load?
A Live Load is typically a moving load. This can be vehicles on a bridge or occupants and vehicles in a building. Dead loads are (relatively permanent loads).
These are simple ways to differentiate the type of load, but why do we care?
The basic answer is, "Because the Code cares."
Why does the Code differentiate between a Live Load and a Dead Load?
There are two reasons why loads are sorted into groups:
  1. Different Load Combinations are described
  2. Different Load Factors are applied
The load combinations are standard groupings of loads that can occur simultaneously. The load factors take into account how accurately a load can be calculated.
In most Codes that use them, Live Loads have a higher load factor than Dead Loads. This is because it is easier to calculate the Dead Loads than it is to calculate the Live Loads. Especially with vehicles, you have little control over the weight of the actual vehicle.
Live Loads have more variability.
This is the only reason why there is a difference between what gets placed in the two groups. The live loads have a higher factor of safety.
What other factors apply?
Another thing to consider is that a moving load has the ability to create an additional Impact Load. If this is the case in this situation, then a separate Impact Load should be included.
What is the end result?
In the end, it may not matter which category gets assigned to the load. The main criteria will be how confident you are in the loading that will be imposed on the structure from the moving platform. If the load isn't likely to change, then you could consider it as a Dead (Permanent) Load. If it is likely to change, then be more conservative in calculating the load or apply a higher factor to it.
All codes will allow you to be more conservative if you choose to be.
  • 3
    $\begingroup$ Although you have a lot of good points in here, you have missed a key difference between dead and live loads - creep/relaxation. As a dead load is always there, it causes creep in concrete / relaxation in steel. A live load is normally not there long enough to cause these effects. $\endgroup$
    – AndyT
    Apr 30, 2015 at 12:10
Since you say a permanent room or platform, I'm assuming you're expecting it to be occupied and used for whatever function.
hazzey does an excellent job of describing the differences between dead and live loads, so I won't go into that here.
Because it is going to be occupied and used, I wouldn't lump the entire load into just dead or just live:
You can easily calculate the weight of the structure, you know the materials being used and you can find out their weights. Place this under dead load, and factor accordingly.
On the other hand, you have an idea of what will be going on in this room/platform, but you can't give as exact a number as above. Find out the appropriate loads for your use case. Place these under live loads.
Add the dead and live loads and boom, you have the weight you need. Since the room will have people on it, and people are unpredictable, placing the entire object under dead load seems irresponsible to me. However, separating the loads will turn out to be more economical than factoring the entire weight as a live load.
A moving load should always be classified as a live load even when its weight is known and remains the same. A dynamic body of mass has an extra degree of freedom. This positional uncertainty calls for a higher factor of safety. Your "permanent" room is not much different from a "permanent" mobile trailer in that both are capable of movement and that the gravitational load do not vary much.
A dead load, on the other hand, is permanent in both magnitude and position. I.e. it is a static load. A static load, being predictable, requires a lower factor of safety.
I would further argue that the classification of load depends on what you are designing. For the hook itself, you may even go for a higher safety factor by classifying it under crane load by reason that failure can result in catastrophic consequences to anyone below or inside the suspended room.
  • $\begingroup$ This really depends on how the item is constrained. Lots of loads can move laterally, but not vertically, and thus applying higher load factors to the vertical component of the weight may be excessively conservative. $\endgroup$
    – Ethan48
    Apr 29, 2015 at 4:22
  • $\begingroup$ @Ethan48, load factor is not related to the direction of load movement. In BS6399, self-weight of furniture and movable partitions are classified as imposed (or live) load and subjected to a higher load factor of up to 1.6 instead of 1.4. Wikipedia has a good explanation on this. $\endgroup$ May 1, 2015 at 3:19
  • $\begingroup$ Errr, correct. But the way the answer sounds to me, talking about a 'dynamic body of mass' is implying some additional loads due to the acceleration/deceleration of the load. That's not likely applicable here. The factors you refer to are because it's harder to accurately characterize the live load. Based on that thought, the structure of the platform would be dead load and the allowable load inside of it would be live load. $\endgroup$
    – Ethan48
    May 1, 2015 at 3:26
  • $\begingroup$ @Ethan48, pardon my English. The word dynamic can mean many things, my definition of it being "non-static" in nature. When classifying a load as a dead load, it is not just the non-variation of its magnitude that is important; the non-variation in its point of application is equally important as well. Unless the code adopted in your jurisdiction explicitly allows for such reduction in load factor, as an Engineer, I wouldn't contemplate taking on professional liability by doing so unilaterally. Bear in mind that the risk to human life is also an important factor when designing a structure. $\endgroup$ May 1, 2015 at 10:24
