I know that channel bandwidth is the range of frequencies it can transmit . Let's say channel bandwidth is 100 Hz . Does that mean it can transmit any signal whose bandwidth is 100Hz regardless of actual values of those frequencies . For example signal 1 has frequencies 200Hz- 300Hz . Signal 2 has frequencies 800Hz-900Hz. Borh signals have badwidth 100Hz Can the channel transmit both of these signals?
    $\begingroup$ it depends on the carrier frequency and the modulation method, which you did not specify here. $\endgroup$ Mar 10 '19 at 5:36
  • $\begingroup$ Let's say I don't modulate the signals $\endgroup$
    – Bisma
    Mar 10 '19 at 6:32
  • $\begingroup$ then you have zero bandwidth. $\endgroup$ Mar 10 '19 at 6:42
