I have to join very rigidly an iron cylinder (length 30 cm, thickness 1.5mm) with an aluminium plate. I'm not expert in welding but I've read that it is not possible to weld these two metals. So I need to use another method, if someone has an idea, let me know.
    $\begingroup$ Some long bolts, a clamping collar for the cylinder and some nuts. $\endgroup$ – Solar Mike Feb 23 at 6:30
