Can anybody tell me how to make a similar welding job - that is to spot weld a thin stainless steel wire mesh to a stainless steel frame. What machine and technique should be used to accomplish this job.
The time has come to replace the torn wire mesh.
Thanks in advance. spot welded stainless steel wire mesh
    $\begingroup$ A spot-welder on a low setting. $\endgroup$
    Feb 19, 2019 at 21:01
  • $\begingroup$ Any specific model of a "spot welder" as I have never seen one. Seen only conventional arc welding. Thanks! $\endgroup$
    – off-signer
    Feb 19, 2019 at 21:08
Not exactly a spot welder but I would consider something like this: Pistol Grip Single Probe Hand Piece – PG2 with Roll Spot
But judging from your picture you might want to consider using a different method then welding. There is quite a bit of corrosion which can result from improper welding. If you need support, just let me know.
  • $\begingroup$ Thanks, sir! But $1750 will be hardly approved. The corrosion results from the harsh atmosphere. $\endgroup$
    – off-signer
    Feb 22, 2019 at 7:35
