Mold for Injection Molding is very expensive and is justified for mass production.
However, at Prototype stage, how we make the same part with less expensive method. I know 3D Printing is a way but it doesn't have Isotropic properties as its a layered structure.
3D Printing is usually meant for visualization purposes and doesn't fulfill needs of Prototype testing. What are methods can be used to produce one-off injection mold type items during prototype development?
3 Answers 3
There are 3D printers that are meant for quick prototyping of injection molds. They print the molding parts, and remove most of the cost of machining the mold. They arent suitable for mass manufacturing since the resulting mold wont last for very long, but is good enough for a small production runs.
Now if you dont have access to something like this. Then we have used 3D printed moulds and injected them with big syringes or vacum casted the parts. This works well for urethanes and silicones. Just as long as your parts are small enough for your 3D prints and you have acess to a suitable 3D printer (DLP or SLA printer, FDM wors very badly). Or if your shape can be machined faser out of some softer material and the costs dont exceed your budget, use that instead.
You can also make a positives (this is often cheaper). And cast a mould out of that thenn use this mould the same way as outlined.
  • $\begingroup$ Thats pretty close to my need...Size of single shot is about 300 mm...Pipe like pieces....300 length ... 1 mm thick and 30 mm dia $\endgroup$ Feb 9, 2019 at 7:14
Some would make it out of clay or similar- but that does not mean it is cheap...
Clay is cheap but the time and skills necessary to create these models are expensive - expensive is a characteristic of unique pre-production models.
  • $\begingroup$ Prototype means that it should be structurally same...Clay is not structurally same as Injection molded plastic $\endgroup$ Feb 9, 2019 at 6:56
  • $\begingroup$ Not always - prototype cars had handmade hand finished panels - once all was decided then the molds were designed so pressings could be used for mass production which involved another level of decisions about release angles, returns etc... $\endgroup$
    Feb 9, 2019 at 7:00
  • $\begingroup$ But a clay mold to provide the shape for the plastic to be molded so that the object can be checked does not require the clay to be structurally the same , the finished object molded in plastic will be the same or similar to the final object - that surely is the purpose ie to get the result to prove the process. $\endgroup$
    Feb 9, 2019 at 7:03
  • $\begingroup$ Got your point...you mean mold made of clay in which molten plastic would be poured... $\endgroup$ Feb 9, 2019 at 7:05
You must focus on 2d-fying your objects if possible, so they can slot and fit together, and place multiple parts in the same injection mould... in that way you can reduce the cost of your final product by many times, by thinking of the product from a production-simplicity viewpoint rather than topology performance, and end up with a crazy cheap product. it's sometimes 10 times cheaper to make 2 half moulds that are ultrasound-welded or latched than a full mould.
I highly recommend that you get involved with a 3d printing shop. 1 kilo of plastic costs 1500 rupees and the electric cost is about 50 rupees. You can refine a design over many generations of testing and consideration.
It forces you to learn about plastic melting points, adhesion, topology optimization, using i.e. ABS which is the most common plastic in toys like lego and car-plastics (strong).
If you 3d print with ABS plastic, you can print at 100 percent fill rate. It glues the filament completely-glued to undernearth and neighboring plastic, thereby 70-80% as strong as ABS moulding.
You can study ABS print versus mould strength comparison and apply them to your 3d shape... enter image description here
You can strengthen an ABS prototype 2x strength by treating it with Acetone Vapor, and painting it with acetone with a brush, where liquid acetone percolates into the part and fuses any voids together. It can make perfectly glassy surfaces. It can acheive strength very near to an injection moulded part.
It depends on the complexity of your part also. Some moulds are 3-4-5 pieces coming in at different angles. Some have only one CNC milled piece of metal.
I bought a RepRap Printer for 22000 rupees. It was 8 hours of great fun to build following a video guide. The resale value two years later is 17000 rupees after printing 7-8 kilos of plastic. It was a very valuable asset for designing and learning plastic.
I also made silicone-detergent cheap silicone moulds for my parts and poured epoxy resine /polyurethane resin in them for fun, but that was a waste of time.
