I am seeking some help related to part of a project I am currently working on, where I require to (data-driven) model the pressure drop due to friction for natural gas flowing along a horizontal pipeline (not underground). I have data for the following variables:
  • P1: Pressure at the entry side.
  • P2 : Pressure at the exit side, P1>P2
  • Q: Volumetric Flow Rate at the entry side
  • T1: Temperature at the entry side.
  • T2: Temperature at the exit side.
  • Z: Compressibility of the natural gas
  • M: Molar Mass of the natural gas.
  • D: Density of the natural gas at the entry side.
I found out that a linear regression fit between [(P1)^0.5 - (P2)^0.5]^0.5 vs Q can be used to obtain an empirical model for the pressure drop because the scatter plot converges acceptable well to a 'straight' line. I am showing the scatter plot below based on the real data here. enter image description here
Can someone kindly suggest me how can I improve the convergence towards a linear plot more by including more variables and hence improving the accuracy of the model? I would be grateful for any insightful help or a general suggestion.
  • $\begingroup$ Are you going to consider roughness & friction factors for the internal wall of the pipe? $\endgroup$ – Fred Feb 8 '19 at 12:56
  • $\begingroup$ yeah, though so its the friction factor. I don't have the data for them from the plant. $\endgroup$ – your_boy_gorja Feb 8 '19 at 13:04
