In Mechanisms and Machines Theory we were introduced to Assur groups and structural analysis where a mechanism is subdivised into elementary Assur groups of different classes. But what is really the practical use of it?
1 Answer
Things have to be assembled. Assur group gives you a catalog of possible ways to make a rigid assembly out of joints. Each joint in this case represents a connection that will be assembled later, or locked down in case of foldable structures meant for reuse.
Being 0 degrees of freedom means that analysis of these is straight forward. Recognizing them will also make kinematic and dynamic analysis easier since you can replace them with a single rigid body.
Since assur groups can be predicted in a organized manner nothing stops you from generating a very big catalogue of these. Allowing you to systematically search for new solutions for the task at hand.
$\begingroup$ As far as I know, they can only be applied on planar mechanisms, is there a similar approach for spatial mechanisms? $\endgroup$ Feb 1, 2019 at 22:06
$\begingroup$ @Abdeljalil Well yes, but there are some cases that dont reflect the theory. So its only 90% accurate, if you refrain from using spherical joints its almost completely accurate. Anyway nearly everything you see around you is designed with planar mechanism in mind $\endgroup$– joojaaFeb 1, 2019 at 22:11
$\begingroup$ Thank you for the clarification, can you recommend resources or books for further reading? The subject is barely mentioned on the web. $\endgroup$ Feb 1, 2019 at 22:18
