I want to be able to precisely rotate a item. For this I have positioned the item on top of a very large gear. It is driven by a smaller gear. When the item is in the correct position, I will lock the smaller gear and the item is fixed in the correct position.
How can I achieve a more precise system without making the large gear larger and the small one smaller(without using motors)?
