The component I am interested in is the blue "head" in the attached image. I call it the sensor head but will like to know if it has a specific industry name enter image desciption here
  • $\begingroup$ Waterproof connection housing? $\endgroup$
    Jan 27, 2019 at 20:21
  • $\begingroup$ Several possibilities without more information. $\endgroup$ Jan 27, 2019 at 22:12
I'd call the blue part the transmitter housing. This usually contains electronics for sensor signal conversion, which converts the sensor (or probe) low level signal to a standard 4-20 mA signal.
The sensor (probe) is the metallic cylinder. And the sensor head (containing the sensing element, membrane/coil) is usually located at the end surface of the sensor.
The part in your image is a Level Transmitter, https://www.aliexpress.com/i/32711941471.html
The silver bit is the transducer, and the blue bit is the transmitter/
