I got a terrible error in the Ansys when I try to create a new project.
I couldn't be able to open the geometry. Every time i open it i get the error "Geometry editor was closed abnormally"
I looked for the solution but didn't get the proper answer.
I useing:
Windows 10;
Ansys 19.2;
notebook Specifications: Lenovo ideapad 320
Intel Pentium 4415U (2.3 ГГц)
RAM 4 ГБ
nVidia GeForce 920МХ
  • $\begingroup$ Have you checked the documentation to see if that processor in that configuration will fully support Ansys? $\endgroup$ – Solar Mike Jan 26 '19 at 23:24
  • $\begingroup$ I checked the documentation, but did not find it. $\endgroup$ – Zero149 Jan 26 '19 at 23:29
  • $\begingroup$ Try on a different machine... Get a friend or colleague to open your model... work the options to narrow down the possibilities... I do wonder if that ideapad has the heavyweight processing power necessary - but I was running Ansys when its version number was below 10... and memory had to be specified as extended or expanded... $\endgroup$ – Solar Mike Jan 26 '19 at 23:32
  • $\begingroup$ On other machine everything works fine. $\endgroup$ – Zero149 Jan 26 '19 at 23:35
