Objective: I want to connect multiple sensors to an item of equipment and visualize the data real-time on an iPad.
Mock of Desired Output:enter image description here
Question: I need advice on the best methods to use to connect multiple sensor data and transfer the data through either wifi or Bluetooth.
Should I use / Is it possible to use Arduino (I have experience with this)
Are there existing wifi modules that allow for such a connection between multiple sensors and devices?
Considerations
  • I have experience with Reactjs and react native to build the application
  • Sensors are (RPM, flow rate, weight, and PSI)
  • This is pretty vague but I'm new to the IoT and acknowledge it will be a challenge.
  • $\begingroup$ The simplest method is to use a wifi based system. Use MQTT or Restful to connect sensor to the cloud. Arduino is good place to start. Check out io.adafruit.com this might be a good place to start. $\endgroup$ Jan 21, 2019 at 23:56
  • $\begingroup$ While an interesting question, it's overly broad and not a good fit for the StackExchange Q&A model. $\endgroup$
    – user16
    Jan 22, 2019 at 13:05
