I was wondering if I could restrict the rotation of a part over another in one direction alone using an electromagnet but allowing me to have a continuous rotation if forced (maybe by using some leverage?) to rotate in that direction.
The concern with using a ratcheted device is intermittent restriction- what I am looking for is a continuous restriction - at any angle of rotation.
I would like to add an image to the question, but not sure how. thus attaching a google drive image. url is https://drive.google.com/file/d/1ugcji9pDeVQiaCE9BgmFnaj6gt8gPMcf/view
Here, 1 will rotate clockwise or counter cw based on an input (not shown) and 2 rotates w.r.t 1, but need an electromagnet that can stop its rotation in counter clockwise direction unless otherwise turned using a 20 kg force (that is leveraged from elsewhere)
  • $\begingroup$ Please explain more as to why a ratchet will not work. The tooth spacing on a ratchet can be very small so that there is almost no reverse movement possible. Also, a magnet would have to be rather large to apply the given force. $\endgroup$ – hazzey Jan 20 '19 at 2:10
  • $\begingroup$ Thanks for the response, I agree to the teeth spacing, but still theoretically it's not a continuous motion $\endgroup$ – Colins V Jacob Jan 23 '19 at 16:33
