Can you make an individually addressable motor strip if you replace led with motors?
  • $\begingroup$ Could you add more detail as to what you are planning? As a gross oversimplification, electrical components are interchangeable as long as they use the same voltage and frequency and run on the same amperage. You may have issues with finding a motor that is interchangeable with a LED. $\endgroup$ – hazzey Jan 17 at 13:45
