I was wondering if this portable power supply will be sufficient for running 4 UVC lamps all at once. If so, for approximately how long?
UVC Lamps: UV Linear Clean & Germicidal Lamp Kit for up to 100 sq. ft. Room with 5ft Cord and Plug (Ozone Free)
Sign up to join this communityI was wondering if this portable power supply will be sufficient for running 4 UVC lamps all at once. If so, for approximately how long?
Rough idea without any losses is 4 * 6 = 24 W
so 100Wh / 24W is just over 4 hours, but no other losses are considered and assumes the full capacity of 100Wh can be used which may not be the case... Also the stated 6W per lamp may not be fully accurate ie start up demand may be different.
