The current capacity of screw press is only 100 kg/hr. Motor is 22kw, shaft RPM is 16, applied torque is 13,120 Nm, theoretical volume is 0.000967 cu m.
  1. Am I correct to say the press is going = 13,120 Nm divided by 0.000967 cu m will get the pressure Nm/cu m?
  2. If it is ok how can I increase the capacity to meet the same applied pressure equal to above answer?
Regards,
Romy
  • $\begingroup$ Increase either the volume delivered per turn at the same speed or increase the rpm for the same volume per turn. $\endgroup$ – Solar Mike Jan 12 at 7:27
If you need to calculate the pressure,
A first estimate, ignoring friction, which can be substantial is,
$ F_{screw}= T/(r*tan (\alpha)) \quad$ r is screw radius , a is pitch angle.
P= F/area of press. by increasing the motor rpm, or increasing the screw pitch you can increase the output, if your motor has enough power.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
