According to Elon in this video (@13:06), he states that the reinforced segments are 70% just dirt, but in normal tunneling, they actually truck the dirt out and bring new dirt in which seems very inefficient.
Is it really that simple or is Elon oversimplifying the challenge?
    $\begingroup$ His fanboys will throw money at it even if he says he's going to import green cheese from the moon to reinforce the tunnel walls ;) $\endgroup$
    – alephzero
    Dec 31, 2018 at 21:56
    $\begingroup$ Elon says a lot of things. Many of those things are oversimplifications. $\endgroup$
    – hazzey
Regarding the word dirt. It depends on what a person means by dirt. Generally, it is understood that dirt means loose material such as soil or sand on or near the surface of the earth.
In mining however, and this may apply to tunneling, the word dirt can sometimes be used used to describe the broken rock, or mined material, that is excavated from the mine or tunnel in the process of mining or tunneling. In this situation it's a form of jargon or colloquialism used by some in the English speaking mining community and possibly the tunneling community.
One reason why locally excavated "dirt" may not be suitable as a ground reinforcing or ground supporting material is that it's strength properties are inadequate for it to be used. Another reason is that it could be a material that expands and contracts when subject to changes in moisture content. This could cause the supporting medium to buckle and decouple from the ground mass. Another reason is the material being removed might be soft.
Materials that are unsuitable include: clay; chalk; talc; limestone; ultramafic rocks such as komatiites ; most sedimentary rocks such a sandstone and mud stone; platey material such as mica; and oxidized or weathered rocks.
Materials that are better suited to be used for ground support purposes are hard, competent, non-friable materials with high strength characteristics, such as basalt and dolerite. Which is why these types or rock are used as aggregate materials for concrete. Generally, these materials need to be brought in sites.
In countries like Bangladesh, situated in a massive river delta, where there are no hard rock sources, broken baked clay is sometimes used as aggregate for road construction purposes.
With present technology dirt is one of the worst possible concrete additives.
It brings the compressive strength of concrete down to unacceptable levels even at fractions of less than 2%.
Elon Musk is one of the few people who has earned the license to say unbelievable things. If his team has come up with a paradigm changing concrete making method, many desert countries, with unlimited dirt supplies would love to hear about it.
As for making brick out of dirt, cost of brick making is not in the polluted raw material, it is manufacturing, fuel, removing pollutants, etc. That's why clean, quality clay and other ingredients are essential.
Brick manufacturing also has a large carbon footprint.
    $\begingroup$ Listening to the part about the bricks, it didn't sound to me as if even he believed what he was saying. $\endgroup$
    – alephzero
    Jan 1, 2019 at 12:04
