I am trying to calculate some rather long and complex drive trains, this is a project that I have worked up to, but its the first problem of its kind I have come across, to try and explain the position I am in please follow my example of how I am trying to calculate the final ratios and if I am going wrong, please can you point out where I have gone wrong and if you have the time, why.
Example: In the image below is a simple drive train, it consists of three shafts with four gears turning.( I know it doesn't look it, but please assume all teeth are of the correct size and mesh with no problems)
  • Shaft 1
    • Input Gear 1 (Purple) has 24 teeth
  • Shaft 2
    • Driven 2 (Red) has 12 teeth
    • Driven 3 (Blue) has 15 teeth
  • Shaft 3
    • Output Gear(Green) has 10 teeth.
So the power travels through Purple,Red, Blue Green.
Now for my Math.
though a 2:1 is connected to a 3:2 I have been calculating the ratio like this, but I am sometimes getting different answers with long (up 12 gears) trains in my project.
I would calculate the final ratio like this:
(12/24)x(15/12)x(10/15) = 0.416(RECUR.)
This is where I am going wrong Is the Final ratio 100:416 (1:0.416) or is it 1/0.416 = 1.666 = ~16:10 or is it something else? Image shows example drive train as described in the example above
Any help is greatly appreciated, im stuck at the moment and need to get on!
According to the Woodgears web site, one takes the gear ratios independently and "adds them together" as shown in the video within the linked site.
In your example, the progression is as follows:
24:12, 15:10 which reduces to 2:1 and 3:2
Two (first ratio) times one and one-half (second ratio) is 3, which provides for a 3:1 increase or a 1:3 reduction if the reverse is created. There is no math between the red and blue gears as one rotation of the red is one rotation of the blue.
  • $\begingroup$ Thank you, this is the issue that I had, several of the gear trains have fixed gears on the shaft similar to the Red/Blue gears and it is this that i am trying to find out. Many Thanks, i would give it a +1 but for some reason rep doesn't translate from one exchange to another, and I seem to lose it when i come back after a few weeks... $\endgroup$ Dec 31, 2018 at 13:07
  • $\begingroup$ So "adds them together" really means "Multiply them together"? $\endgroup$ May 10, 2019 at 11:22
  • $\begingroup$ Yes, I realize now that the terminology is poorly phrased for this operation. $\endgroup$
    – fred_dot_u
    May 10, 2019 at 16:46
