Please could someone explain the reason for using negative superscripts in SI units, and more precisely when to use negative versus positive?
I do not understand, for example, why the volume of a fuel would be given in m3 but heat of combustion would be given in J m-3.
Negative exponents means per. In countries that were heavily influenced by the British, units such as meters per second would most likely be written $m/s$. In Europe and elsewhere it could be written with negative exponents as $m.s^{-1}$.
In your example $J m^{-3}$ means joules per cubic meter.
