How can you calculate wear of steel pipe that is transferring sand laden fluid under pressure?
closed as too broad by OpticalResonator, Solar Mike, Fred, Sam Farjamirad, user8055 Dec 31 '18 at 15:26
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • $\begingroup$ Lacks so much detail... velocity, solid to liquid ratio, bends, pipe roughness, grain size etc etc etc $\endgroup$ – Solar Mike Dec 27 '18 at 21:31
