It is will known that increasing cooling of a metal casting will lead to finer micro-structure which mean higher mechanical properties. If I have 2 molds one is thick copper die ,& second is just thin-walled copper cup or mold cooled by water. which one of them excepted to cool the molten metal i.e. aluminium faster ?
the calculated heat diffusivity of copper is : thermal conductivity x specific heat x density = 385 x 0.385 x 8960 = 1328096 m²/s
while for water it is just : 0.6 x 4.2 x 1000 = 2520 m²/s only !!
so, the copper can transfere heat 527 times faster than water.
by calculations it seems that copper die have higher cooling power as it has higher thermal diffusivity , but in real life it seems water have more cooling power. I am so confused.
