I am thinking that air (if it is still) is a very good insulator.
So why aren't we putting the window shutter far away from the window?
It would have more air between the window and the shutter and the Question: it would cause better insulation?
Or above a few centimeters thickness, the airflow would start anyways by itself and it would just only backfire?
  • $\begingroup$ This is possibly a duplicate of the question here. engineering.stackexchange.com/questions/24826/… $\endgroup$ – Jeffrey J Weimer Dec 3 '18 at 13:33
  • $\begingroup$ I cannot comment there (not having 50 points) to ask for further infos in the link you mentioned :\ because on that link I don't understand what are the letters mentioned in the formulas. can you pls update that answer with more details on what is what, ex.: what is "A" or "ΔT" or would my theory work? to make the distance bigger between the windows and the shutter many thanks :) $\endgroup$ – KollarA Dec 3 '18 at 20:15
  • $\begingroup$ I have updated the explanation and added examples. $\endgroup$ – Jeffrey J Weimer Dec 4 '18 at 0:04
The distance between the window shutters and windows is mostly dependant on the thickness of the walls.
Air can flow through much smaller space such as the fins of amplifiers heat sinks or many electronics heatsinks that don't use a fan.
