What is the difference between LT and T directions in MMPDS (formerly MIL-Handbook 5)?
I hand understood that forming metal orients its grains, destroying the isotropic nature of 'pure metal' and that the "Long" direction is the length of the sheet/extrusion/etc, and that there were two transverse directions. There is the "Short Traverse" which would be the thickness (or "depth") of the sheet/extrusion/etc. There is also the "Long Traverse" direction which would be the width of the sheet/extrusion/etc.
But then MMPDS throws in a "T". Is this just for the times when you cannot distinguish between LT and ST (such as in a rod)? I also see datasets where specimen orientations are T and ST, which furthers my confusion. MMPDS itself doesn't seem to offer much further guidance.
Any explanations?
I believe MMPDS is the new name for Mil-Handbook 5. I have the 1998 version and it defines "T" as `Applied torsional moment; transverse (grain direction); subscript “transverse”. Also see the figure below from Mil-Handbook 5.
In the figure, the "L", "T", and "S" planes are marked clearly. Note that "T" and "L-T" indicate the same plane.
MIL-Handbook 5 1998 definitions
