I'm trying to use ANSYS to solve statically a dynamic problem. As shown in the image below, there is an orange bar that is constraint to slide horizontally only and attached to another bar (pink) through a pin joint. When the orange bar is subjected to a momentary external force, it accelerates horizontally and as a result the pink bar behaves as a pendulum.
I modeled the case in ADAMS to get all the needed kinematics/dynamics info (accelerations, pin joint reactions, angle Vs time and etc.) and now would like to use ANSYS in order to obtain the stress and deflection fields. I am familiar with the flex body option in ADAMS and actually experienced with it a little, but would like to analyze the stress with a tool I feel more comfortable with.
As long as I understand, in cases by which the rigid body is actually moving - there is an option called Inertia relief. The general idea behind it is to "remove" the loads causing a motion in order to solve a static problem and compute the stress acting on the body. In this case, if I use a pin joint in ANSYS and apply horizontal acceleration on the pink bar - the all body would move. Alternatively, I can fix the bar to the pin joint in all 6 DOF but then I'll get an artificial and non-realistic bending moment (this moment generates the motion and does not bend the bar in reality). However, when using this Inertia relief option, all the support reactions are zeroed - and this should not be the case here. I need to fix the motion in X and Y directions in the pin joint while allowing the bar to rotate along the Z axis and solve the problem statically. I think to not use the Inertia relief option and alternately add linear acceleration (D'alembert style) but I'm not sure about it. Any ideas or thought?
Well, I'm going to answer myself here - just for sharing the information with others.
I figured out that what I was missing is adding the effect of the angular acceleration. I avoided using the Inertia relief option, and alternatively added both the linear and angular accelerations in opposite directions (D'alembert principle). I got those accelerations from the ADAMS dynamic analysis as stated in the question. The pin joint is constraint in all 6 DOF artificially. However, since there was no net moment about this axis (the effect of both accelerations cancelled each other) - there was no bending moment and the stress distribution seems realistic now.
