I want a rod to freely rotate 360°, it stands vertically and the rod is gonna carry some construction below it. The rod should be fixated to the e.g. the wall or anything on a ceiling.
What parts do I need to make this possible? How do I fixate the rod onto the ceiling without stopping it's rotation?
I have looked up about eccentric locking collar, is this the standard solution? Or are there easier ways to fix the vertical rod (falling down the floor) without stopping its movement?
  • $\begingroup$ How much load? How fast will it rotate? Is the load off-centre? $\endgroup$
    Oct 31, 2018 at 5:44
With a thrust bearing. A conventional bearing supports radial loads; a thrust bearing supports axial loads.
You could use an old dead electrical drill's chuck and shank.
Or even hang the whole drill from the ceiling. If you need a bigger or stronger gadget, you can use an old industrial hammer drill or jack hammer tip.
