According to this Wikipedia page, vulcanization is an important process to make rubber harder and more durable. However, another Wikipedia page says that plasticizers play a significant role in rubber manufacturing, acting as a softener.
Is there a reason why both are needed when processing rubber? It seems to me that they exhibit an exact opposite effect on the rubber being processed and hence only one is needed.
yes, there is, as follows.
Unvulcanized rubber will soften and turn into taffy when it gets warm. Vulcanization cross-links the polymer strands and prevents the rubber from turning into taffy at high temperatures.
This also necessarily makes the rubber stiffer and more resistant to deformation at lower temperatures, which can yield a rubber compound which is not soft enough for a particular application. This tendency can be counteracted by milling mineral oils (plasticizers) into the rubber to get the rubber molecules to slip more easily past one another (within the limits set by the cross-linking).
This means that the process of engineering a rubber batch to have the right combination of flexibility and durability involves balancing the benefit of cross-linking against the need for rubber-like behavior, and this involves careful blending of plasticizers into the rubber resin. In so doing, the engineer can get anything from supersoft to almost rock-hard rubber, dialed-in for a broad range of special applications.
  • $\begingroup$ Can't you just counter the stiffness of the rubber at low temperature by introducing less cross-links? Or does the usage of plasticizers enables a finer control on the stiffness? $\endgroup$
    – dylux
    Oct 29, 2018 at 9:21
    $\begingroup$ the rubber loses its elasticity and will not spring back when the loads on it are released if you "go short" on the crosslinking, for good flexibility at low temperatures, a better solution is to switch from natural or synthetic rubbers to silicone rubbers, which perform better but are much more expensive. $\endgroup$ Oct 29, 2018 at 17:55
