I need to design an active high pass filter circuit that implements the following transfer function:
$$G(s)= 4.15\times\dfrac{s+530}{s+2200}$$
where, $K = 4.15$, Pole @ 2200 rad/s and Zero @ 530 rad/s.
I have already designed the non-inverting amplifier component of this circuit, using two resistors of value 1k and 4.15k. The issue I have is the passive component of the circuit and trying to control the poles and zeros of the transfer function. This is all I have attempted, I am completely stuck.
  • $\begingroup$ Well three points : One, have you considered the Electronics Stack and Two, What have you done so far? Three, is this homework? $\endgroup$
    Commented Oct 22, 2018 at 5:42
    $\begingroup$ Posted and Answered here : electronics.stackexchange.com/q/402519/152903 $\endgroup$
    Commented Oct 22, 2018 at 9:46
  • $\begingroup$ This looks like a homework question. In order for such questions to be answered in this site, we need you to add details describing the precise problem you're having. What have you tried to solve this yourself? Please edit your question to include this information. $\endgroup$
    – Wasabi
    Commented Oct 22, 2018 at 11:03
  • $\begingroup$ Can you show your non-inverting amplifier design? $\endgroup$
    – 706Astor
    Commented Nov 2, 2018 at 16:09
