I can't seem to figure out the proper left view for the following image, and the full and half sectional cutout for the left and front projection.
    $\begingroup$ Sorry but i have difficulties distinguishing between dashed lines and lines, i cannot read the map. $\endgroup$ Oct 18, 2018 at 16:08
  • $\begingroup$ Yes the dashed line at end rightmost circle is a bit distracting but i will give a hint there are 2 ramps and a t shaped flat $\endgroup$
    – joojaa
    Oct 18, 2018 at 17:49
  • $\begingroup$ I'll make you a 3D model of this later this evening - on mobile now. There is just enough information to define the shape, although it's lacking in dimensions... What's this for? $\endgroup$ Oct 18, 2018 at 19:35
I have made a 3D model of my best guess for this model from your drawing. I've then generated a crib-sheet for the computer generated standard views (first angle projection, as per your sketch), and for some section views. Hopefully one of these provides the information that you're after? - have a look below, and let me know if you have any questions!
Best Guess 3D model 2D Drawing Cribsheet
  • $\begingroup$ Thank you for your consideration and response. Your comments and support really helped to solve my problem. And though some of the lines were unclear, i managed to find a better image @Jonathan R Swift $\endgroup$
    – Person
    Nov 22, 2018 at 8:21
  • $\begingroup$ I'd love to share it, but I cant seem to find the option for adding pictures in the comment $\endgroup$
    – Person
    Nov 22, 2018 at 8:25
  • $\begingroup$ Hi - You can upload the image to a sharing site like imgur.com and then paste a link to the image as a comment? $\endgroup$ Nov 22, 2018 at 8:48
  • $\begingroup$ Ok. And if you could please take a look at my recent post as well. Thank you.engineering.stackexchange.com/questions/24793/… $\endgroup$
    – Person
    Nov 22, 2018 at 9:22
