I'm using the Eurocodes for some structural analysis and am looking for the limiting value of deflection of a plate. EN 1993-1-7, Section 8.2 states: For limiting values of out of plane deflection w see application standard.
I'm not sure to which application standard this is referring.
Can anyone point me in the right direction?
Thanks
I think it means the relevant section of EN 1993 for the specific use (application) of the plated structure. A partial table of contents of EN 1993 includes
  • Part 2: Steel Bridges
  • Part 3-1: Towers, masts and chimneys
  • Part 3-2: Towers, masts and chimneys - Chimneys
  • Part 4-1: Silos
  • Part 4-2: Tanks
  • Part 4-3: Pipelines
  • Part 5: Piling
  • Part 6: Crane supporting structures
In case anyone else is ever looking for a limiting case for deflection of plates, in relation to the Eurocodes, you can find this in:
EN 1993-4-1 Section 9.8.2 (2)
Hope this helps someone!
  • $\begingroup$ If this is the correct answer, why do you still have @alephzero's marked as accepted? $\endgroup$
    – Wasabi
    Oct 21 '18 at 19:04
