I am a robotics student and new to aeronautics. My task for a project is to build a flying wing drone with limited wingspan (<1m), 25cm chord at wing root, total load of 2.5kg (1.5kg empty) and cruise speed of 25m/s. It is also worth noting that it is a VTOL and so it will not be subject to speeds lower than 20m/s since there will be no takeoff.
I am currently investigating how to passively (without using control surfaces) guarantee pitch stability. Since I am limited in wingspan, I am exploring a swept C-wing design (with horizontal winglets forming a C shape with the wing) instead of using washout since the twist would considerably reduce lift for such a low wingspan.
I have been searching for resources on horizontal stabilizers at wingtips but I have not found a lot (apart from "Tip Extensions , Winglets , and C-wings : Conceptual Design and Optimization" by Shangguo Ning and Ilan Kroo, and "Preliminary Investigation of a Self-trimming Non-planar Wing using Adaptive Utilities" by M. Trapani, M. Pleißner, A. T. Isikveren,K. Wieczorek).
Is there another name for such a design that would help me find more resources? Or is this design rarely used for some reason? What considerations should I be taking when designing something like this?
  • Might look into the canard design which uses a small foil forward of the lifting foil for pitch control – Donald Gibson Oct 12 at 3:53
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
