I have an Aluminium square cross sectional rod of $20mm$ X $20mm$. Length 700mm. At the end of this rod there is a mass of $660$ $g$ attached. My question is what torque do i need to lift this mass up assuming my pivot point is at the other extreme of the rod? And how do i consider the mass of the rod in the calculations!
  • $\begingroup$ Do you mean to lift the mass like what cranes do ? I mean pure vertical or over an angle ? $\endgroup$
    – user14407
    Oct 6, 2018 at 9:48
  • $\begingroup$ Not exactly . The motor is lifting the rod as well as the mass(attached at the end) together over an angle unlike Cranes. Lets assume the the rod and the mass are initially horizontal to a plane. $\endgroup$
    – Mojiz
    Oct 6, 2018 at 9:57
  • $\begingroup$ You can consider the mass of the beam as a weightless beam and a point load, at the midpoint of beam $\endgroup$ Oct 6, 2018 at 10:12
  • $\begingroup$ @JonathanRSwift Point load as in taking the mass of beam plus the additional mass at the end as one acting at midpoint? $\endgroup$
    – Mojiz
    Oct 6, 2018 at 10:20
  • $\begingroup$ No, You have to superpose the 660 g and the mass of the beam, if you want to work very accurate you can integrate over the mass of beam $\endgroup$
    – user14407
    Oct 6, 2018 at 10:34
The angular momentum of a rod or beam rotating about one end is its angular momentum about the center of mass of the rod plus mass times (l/2)^2, in this case, parallel axis momentum theory. $$L = m\frac{l^2}{12} +m\times (l/2)^2 = ml^2/3 $$ Where m is the mass and l the length of the aluminum rod, 700mm.
So the torque needed is
$T= 1/3(ml^2) + 660l$
