Sometimes we need a strong threaded joint in some part that is produced using molding. Say, this part itself is plastic. Then we design the part with a hole and insert there a.. "threaded bushing"? I don't know the proper name for this element in English. In Russian it is "закладная втулка" (insertable bushing/cylinder/etc - втулка/vtulka is a catch-all term for all things cylindrical that are used in an "axial manner" - something is inserted into them, or they are inserted somewhere, or both). I'm looking for a proper term in English.
I googled for закладная втулка and found this example relevant to my text:
In the text that I'm translating into English, these brass insertable threaded elements in a plastic part produced using molding look like this:
I found a DIN on one Russian page describing "закладная втулка" and this DIN led me to English terms "threaded bushing", "threaded insert". Are these okay?
As they are going into blind holes, then threaded insert would be better.
  • $\begingroup$ Would we use the term "threaded bushing" for inserts that pass through the item (have holes both sides of the item)? $\endgroup$ Commented Oct 4, 2018 at 12:05
    $\begingroup$ For me, a bush is not threaded... it is a type of bearing... $\endgroup$
    Commented Oct 4, 2018 at 12:17
    $\begingroup$ The top picture you show are blind nuts or domed nuts $\endgroup$
    Commented Oct 4, 2018 at 12:19
  • $\begingroup$ @SolarMike "For me, a bush is not threaded... it is a type of bearing" Fastener suppliers don't agree with that. See google for lots of examples. $\endgroup$
    – alephzero
    Commented Oct 4, 2018 at 21:26
    $\begingroup$ @CopperKettle I concur with Mike that bushing is a bearing surface (подшипник скольжения). The only thing that comes to mind if someone says "threaded bushing" is a part that has threads on the outside and a smooth cylindrical surface on the inside. That's not the case with the parts in the O.P. $\endgroup$ Commented Oct 5, 2018 at 1:00
This is called "threaded insert" in English.
For more context, here are product page for threaded inserts for plastic: this and this. Both of are major manufacturers based in US.
Additional examples of plastic parts with threaded inserts: this and this.
